Help! Leaking waste/soil pipe
22 Sep 2004
Hi
Just came downstairs to internal garage and there is a puddle of water which appears to have leaked out of the upstairs toilet/bathroom waste. Have confirmed that this is where it is coming from by flushing the toilet and the puddle got bigger. The pipe has like a trap door on it done up with screws which is where the leak seems to be coming from. What should I do? Is this something I should tackle myself or should i get a professional in? also do you reckon this is something that will be covered by home insurance? thanks heaps if anyone can give advice.
have you tried tightening the hatch
also get someone to flush the toilet if the leak carries on more than
a few seconds you may have a blockage
big all
thank for your reply. it does seem to keep leaking out slowly after toilet flushed so i guess it must be a blockage causing it. Should i open the hatch and try to clear it myself or do you think it is likely to be a horrible job that is better for a professional to do?
well i would call on my brother he is the plumber
how ever high the the access hatch is off the ground is how much poo
youve got to deal with plus probably a lot more
personaly i would wait for the clever boys and girls with poo stained
overalls on for a sensible solution [wouldnt want you up to your neck
in poo literaly] :roll: :roll: :wink:
big all
