Not sure if this should go here but
Im about to fit 3 rooms with chamfer oak veneer mdf skirt, I will be scribe jointing the internals. I have a tennon saw but recon that i may get on better with a pull saw as from what I can findout they give a much smoother and fine cut.
So is it worth bothering if so - which one can you recomend
or just use my tennon. (dont need a coping saw as the profile is chamfer
