Help me find a better saw than a tennon
27 Jan 2011
UK
Not sure if this should go here but
Im about to fit 3 rooms with chamfer oak veneer mdf skirt, I will be scribe jointing the internals. I have a tennon saw but recon that i may get on better with a pull saw as from what I can findout they give a much smoother and fine cut.
So is it worth bothering if so - which one can you recomend
or just use my tennon. (dont need a coping saw as the profile is chamfer
I think you will be better of with a sliding chop saw with a fine cross cut blade,as for which one to buy it depends on your budget and frequency of use why not throw it open,on the tools and materials section
I have a mitre saw for the externals but I was asking about the
Never used a pull saw but they sound a better finer cut than a tennon
Heres one idea butt joint the internals on the oak veneered skirting then apply oak trim to skirting tops mitre internals and cover mdf at same time job done
