In each case, for both my neighbour and I, the indoor vertical wall underneath the firewall is wet.
The firewall / roof flashing seems okay, along with the roof tiles and membrane, and so I believe that the leak is caused by cracks in the cement under the concrete paving slabs on the firewall, and a lack of dedicated coping stones (to protect the cement from the brunt of any bad weather)
** Update : Zooming in on the pics it looks like the existing DPC could be the route cause of the cracks ? **
i) Looking at the two photos, do you agree?
ii) If I wanted to replace these old slabs with proper coping stones, should I affix them using a cement mix with external PVA added to help waterproof ?
iii) Do I need to consider a DPC ? - or can I just lay 2 - 3cm of cement on top of the existing flashing (after removing the old slabs and cement) and then attach new Coping stones on that?
All guidance / suggestions very welcome
Many thanks in advance,
