Help Needed
1 Mar 2008
Buckinghamshire
I am currently having a conservatory built and once it's complete I want to remove my existing patio window and replace it with an internal french door set. Trouble is I can't find a frame and doors to fit.
The size reqd is 1800 x 2100.
Can anyone help???? :?
Have one made up by a d/glazing company. they will fit to any size hole you have...
Have a look on Ebay. There are around 102 items in"Home & Garden", "patio doors" and, on the first page there is a set with the dimensions which you require. Lots of money to be saved.
1800 x 2100 is a standard frame size, so I don't know why you can't find any.
All the merchants that stock ready made doorsets should carry this size.
Fit a DG external French door set; not only will they keep more heat in but will prevent you from breaching building regulations by fitting an internal door between your cons. & the house. I know many folks do it but I assume you do realise your not supposed to & it could lead to probs. when you come to sell up!
