moved in 1950's house at christmas. Its a baxi bermuda back boiler.
i know it uses gravity fed water for the heating and hotwater. I took 2 rads off to decorate downstairs. I put one, on. I understand the feed pipe is supposed to top up the rads when there is leakage or evap.
First the hot water stopped and the heating (rads) was fine. I put one of the missing rads back on.
Few days later found the heating not working well, various rads would go cold or cool, i can not say it was just upstairs or downstairs. and got cooler and now, hardly anything.
I also discovered the speed control for the pump was messed up, so i bypassed this so it is on about 3/4 power.
I do not know if the rads are being replenished with water, as the tank in the loft doesnt empty at all, even when i drew 2 buckets of water off. The tank has manky rusty coloured fuzz in the water. the rads were a bit black gungy when i took them off.
i dont know if
a) the pump is not slimmed up or is it working right?
b) is there enough water?
c) can i fill the system with water if the regular way is blocked?
d) would an air pocket do this?
ITS COLD AND KNOW THEYD CHARGE ME LOADS FOR CALL OUT. I need to know a procedure to check this out and then go through it. Were all tired moving and them chrimboe, were so stressed.
Thanks,guys.............. x
Rich
i dont know if
Rich
