Someone please help, we have just purchased a new conservatory, and erected it ourselves, all was going well until the double glazed units were fitted, first one of the French doors developed a crack it started in the welded mitre joint, it spread across the door frame out to wards the hinge side, the next morning several of the windows had similar cracks, all the cracks seemed to start in the mitre-- and spread right through the weld or shoot of to the side of the frames, the framework was put up as per instruction , a 4 ft spirit level was used throughout the build,everything is level. what on earth could be causing this to happen ?
Thank you in advance.
Tilly-1
Tilly-1
