Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I have an old boiler Thorn M30/42B. There is not hot water but CH is working fine. Can some one please help me.
Also: Before the H/W going down, When hot water was switched on, It used to heat up the radiators TOO!!
have a look in the airing cupboard for a motorised valve. It looks like a metal box about 3 inchesx 2 inches it will have a flex (cable) running into it. This is probably malfunctioning. A job 4 a competent plumber.
