When I tried to fit my toilet to its waste pipe I found that the 110mm pipe sticking out of the wall is slighly lower than the outlet of the toilet. I can get the straight waste connector that I have (KWIKFIT SK40) to fit onto the toilet and into the plastic waste pipe but it is really pinching the rubber gasket at the top of the plastic waste pipe (looser at the bottom) this is before I have added a silicone bed under the toilet which will probably make it even tighter. My gut feeling is that I could end up with a leak. I believe I can get an OFFSET CONNECTOR which should allow the gasket to set more centrally in the waste pipe. I found one on the screwfix website (Floplast SP102) but I am not sure how much offset this has. It also has one bad review!
Any suggestions on a good quality offset connector with a small offset?
Steve
Steve
