Hope someone can help with this. I'm getting patchess and roughness on an internal wall. It only affects one part of the wall.
A recent picture is attached. Since then, I've stripped the paint, reskimmed, primed with Zinsser BIN and repainted. Sadly, the staining/roughness at the bottom has come back, as has a similarly stained patch about four feet above the skirting. The bits in the middle (stained in the photo) now seem OK.
Skirting is perfectly dry. Paint at the stained/rough bits leaves a mark on the fingertips, i.e. a bit chalkly.
Any ideas? I guessed not rising damp (dry skirting and four feet up patch). Condensation?
Do the symptoms ring any bells with anyone?
Thanks in advance View media item 68097
