- Joined
- 10 Nov 2009
- Messages
- 4
- Reaction score
- 1
- Country
We have a rented flat which is about 7 years old. There are no instructions on how to use the underfloor heating and so we need help please. The flat is on Economy 7 and there are no storage heaters - just the underfloor heating.
So, we have a box in the cupboard called a Protemp Advance II. It has a dial in it that you can turn, and the settings are a bit weird. Imagine a clock with the numbers 12 - 6 (though there are no numbers - just lines). There's an arrow pointing from 2 - 12 with the words "increase economy". There's an arrow pointing from 4 - 6 with the words "increase heating". Between 2 and 3 there is text "normal - 8 hour white meter" and between 3 & 4 there is text "normal - all off peak tariffs" and "normal - 7 hour white meter".
We have an 8 hour meter so our reaction was to turn the dial to the text between 2 & 3, and to turn up the thermostat on the wall (to 3 out of a maximum of 7), thinking that overnight the flat would heat up. But this morning it's as cold as it was last night.
So our 3 questions are
1) what did we do wrong and why didn't it heat up overnight?
2) is there a way to manually override it during the day and make the heating come on, by using the weird dial in some way? We're cold!
Thanks!
Thanks!
