I have moved in to a home about 10 years old, stripping vinyl wallpaper off a bedroom wall.
The vinyl is coming off on its own, in some parts the backing paper is also coming off, but also removing a layer of original paint too.
The problem is if I strip off the backing paper, some paint will also come off. Should I therefore also remove the paint? If so, what should go onto the plasterboard - just paint? I believe the plasterboard in question is pink/purple - fire resistant?
Thank you.
Thank you.
