Guys
Newbie here. I need help/advice on the above boiler. I've had nothing but problems with this boiler.
The heating side of it isn't bad, it takes about an hour or so to spark up and go ...... Don't really know if this is normal or not. I turn the dial to heating or heating /hot water and it'll spark up straight away ..... only to switch itself back off a couple of minutes later. It'll do this for a while until the radiators start heating up.
The other problem I have is the hot water side of it. I turn to dial to Hot Water. I then run the tap. I should expect the hot water light to come on but it doesn't. It doesn't come on .... ever. I've had the diaphram, thermostates changed but it worked for a day or so and then went back to the way it was.
The only way I get hot water is to turn the dial to heating, wait a couple of hours so the tank builds up enough hot water.
Any help/ideas is much apprecaited.
Losty
Losty
