help required
10 Dec 2008
Yorkshire
Hi Guys,
right had a dual coiled cylinder (Albion SL120 seperate shower coil) go caput on the shower side, tried to tap the shower off the standard hot water side but no pressure to the shower although all taps work fine, put a booster pump on (grunfoss 15/90 home boost pump) still to no avail however does work if you run a tap, any ides how to solve this problem.
