Aqualisa Axis Digital Pumped shower or Aqualisa Axis Thermo
10 Jul 2008
London
I was looking to get an Aqualisa Axis Shower, either the concealed digital pumped shower or the Aqualisa Axis Concealed Thermo shower with a seperate pump. I would appreciate any advice. Right now I have a gravity fed system, immersion coil hot water cylinder. The cold water pressure is good but the hot water is low in all taps. I assume if I got the Axis Thermo with a seperate pump I could get a single impeller pump that would increase hot water pressure for the shower and possibly bath & basin. If I went with the Axis digital pumped then only the shower pressure would be okay, but not sure how it would affect an already good cold water pressure. Thanks!
Are you replacing a shower or installing one from scratch?
What cold supply do you have in the room where it's going - mains or tank-fed cold?
I will be replacimg an electric shower. I have a hot water cylinder but not sure where the cold water comes from? How do I know or find out? I live on the ground floor on a 2 story block of flats. There is a communial water tank above but I think it s a boiler for heating (radiator).
