Help Required
11 Feb 2006
I had to take a radiator off the wall to re-fix it.Now i have no hot water or heating.I think the problem maybe an airlock :? but dont know how to sort it out.Any advice?
The boiler i have is a Potterton Flamingo 50s.
Ps. When i switch the water/heating on the Boiler lights up for approx 30 secs and then switches itself back off :?
I've read the "Sticky: Look Here First - FAQ" thread.I can't find anything that relates to the problem i have :(
Anyone?
Hi Saraht: I don't what type your boiler is, but if it is a combi and you have a preesure gauge which showed about 1 bar. The pressure would be lost when you refitted the radiator and allowed it to refill with water. So it may be a simple matter of re- instating the pressure, using the filling loop.
So do you know if it's a combi ?
:roll: :roll: :roll:
sounds like the pump or an airlock.
More info about the system needed
hiya,
same thing happened to me the other day.
it just needs refilling for a few seconds then pressure gauge will rise and sorted..
PS boiler was saunier duval
Talk about the blind leading the blind!
This is a very old system boiler!
Probably air in the pump or system, look in the system bits at the top of the site page.
