Hi thanks for taking the time to read this.
I have 1 radiator working out of 8 in the house.
I have had a new boiler installed as thought the old one was not up to the job plus it packed in so think i can discount that.
So far i have drained the hole system and found small partials. So today i have gone round all on the radiators and injected cleaning fluid, system is now on and will see how that goes over night.
I suspected that the radiators might be blocked so i have taken one of the wall and flushed it in the back garden the flow seemed to be good to me ( will start doing the rest tomorrow. At the same time i removed the valves either side and changed them, on checking the old one they seemed to be okay ( could blow through them ).
On 4 of the radiators one of the pipes connected feels hot but the other feels cold , what has confused me as well is that it is not always what i would think it the supply valve ( the one you can adjust to get more or less heat, or it can be the manual valve you have to use a spanner to close) hope that makes sense.
Plus on the radiator that does work the heat seems to come in from the manual valve side and out of the temp regulated valve even thought the flow arrow on the valve is against this ??
On the other radiators the inlet and outlet pipe work are both cold.
Any suggestions as to a way forward would be great, should i be thinking of getting a power flush, when i have spoken to central heating people about it them seem to avoid the job.
When I bleed the radiators there seems to be a goo pressure behind the valve.
Thanks for any help.
