Hi there, if you haven't got fed up with me on my previous thread please contribute your expertise/experience.
If you were to design a system for the following requirements what exactly would you recommend? Some of the following already exists, some is being built as we speak and some will hopefully be built once plans accepted
1) Approx 3200 sq ft ( 1600sqft gf, 1200sqft ff, 400sqft loft floor)
2) Four showers (one electric on ground, two non electric on first and two non electric in loft)
3) Two baths, both on first floor
4) Approx 35+ rads.
The house is double glazed at the back but has original single glazed to the front and sides.
I have done a mickey mouse flow test. On the kitchen sink it came out at about 17l/min, when I tested an external tap (ie on the outside wall of the property) it was close to 20l/min
I don't think I'll be able to measure the pressure, so unless you can tell from the flow we'll have to make some assumptions for now.
Every morning AT LEAST two showers need to run at the same time as well as some sinks being filled with hot water. The system needs to be able to handle at least this requirement with ease.
Please assume no space constraints
Thanks in advance for your time and expertise
4) Approx 35+ rads.
