- Joined
- 13 Dec 2022
- Messages
- 59
- Reaction score
- 1
- Country
So i've got my plans back from Wunda and about to start laying in the next week, however I need to install a floor sensor to measure and restrict maximum floor temp to preserve flooring correctly.
This is what I'd be installing https://heatmisershop.co.uk/remote-sensor-probe-3m/
Now the layouts in each route are snail pattern and so I'd need to run this over the existing routes somehow, I see some people encase theirs in a section of pipe, but worry that if I run another 16mm pipe over the top of the existing ones to get towards the center of the room the build up might be too high? I can't route in the insulation layer unless I route a section out first before putting down a slip layer perhaps, but pushing the membrane into that won't be easy. Thoughts? What did you do?
