Apologies in advance for seeming rather vague but I hope those with more knowledge than me will be able to fill in the blanks and will be able to give a view as to who is right in this scenario:
Im currently getting quotes to replace my boiler with a combi. The existing system I have is old and is located downstairs in a 3 bed semi. I would like to move the new boiler into another room at the same time as changing it to a combi. Anway my question relates to the width of the hot and cold water pipework which is currently 22mm. As I undersatnd it the same pipework that will feed from a combi will be 15mm. One plumber is saying that to do the job properly he would quote for replacing all the 22mm with 15mm for the whole of upstairs (single bathroom- bath and sink ) as to leave the 22mm would give a disapointing result (presumably flow). He thinks the downstairs is already 15mm.
I should add that the proposed combi will be a good one- Worcester Bosch or Valliant with a flow rate of about 15 litres per min and also that I have very very good mains pressure.
I never was very good at physics but I struggle to see how the amount of water that will come out of an upstairs tap will be effected by whether its coming out of a 15mm or a 22mm pipe. Sure on the 15mm it will come out under a higher pressure maybe, but there wont be anymore water. That maybe wrong, Im not sure. If there will be a difference can someone explain what it will and what effect it will have? I should also add that I plan to fit a thermostatic shower upstairs in the near future so not sure if that changes things
Are there any plumbers hovering that could give us a view or people who have had the same question?
Thanks in advance for any help
