S
snadge
Hi
I have noticed that our central heating (combi boiler) rad pipes are 15mm that feed off each other ... is this OK/Safe..?
what I mean is the Boiler has the 22mm pipes coming off the boiler but then 15mm pipes along to the rads and each rad is fed from another rads 15mm pipe, returns are the same... my dad tells me that the plumber told him that your supposed to have 22mm pipes under the floor upstairs and down (we dont) and each rad has its own 15mm pipe coming off the 22mm one and fed back to the return 22m pipe on its own 15mm one - but ours is just a maze of 15mm pipes.
is this a problem?
whoever done the pipework WAS a cowboy, Im not a plumber but Ive seen some major flip-ups under the floor with the pipework.
thanks in advance
is this a problem?
thanks in advance
