Hi there
I'm in my first winter in a new house and I've spent the last few weeks trying to figure out how the CH system works (open vent F&E, Potterton Osprey), particularly as the rads weren't getting as hot as I thought they should.
I'm no expert but in discussion with a few friends I've managed to get a pretty good idea of how it all hangs together. Also managed to improve the balancing of the rads (thanks to my research on here) so the heat distribution is much better.
The one thing no one can figure out is the purpose of one of the gate valves. Rather than trying to describe it I've got a a couple of pics of the set up.
http://s251.photobucket.com/albums/gg301/giw121/
The mystery valve is the one just above the 'Return' text in the first pic. It was fully open originally but all this seemed to be doing was letting half the pumped flow go straight back to the boiler (the return to the boiler is just below the valve and goes through the ply). I closed it (but not completely) and the rads felt hotter and the boiler seemed to start and stop less often than it used to.
However, the prob I have now is that when the hall thermostat reaches temp and switches the central heating off (remembering that it's still officially on as per the boiler programmer) then there's a loud whine that seems to come from the pump. If I up the thermo a few degrees past the click then the noise goes.
Sorry to bang on but I wanted to make sure there's enough info.
Please can someone tell me what this valve does and whether it should be open/closed/in between.
Many thanks
Gary
Many thanks
Gary
