ok ive noticed that our central heating isnt quite getting hot enough.
Ive checked radiators to see if they need bleeding which they dont.
I have been into the loft and noticed the ball cock was not operationg so ive held it down to fill the water up just below the over flow pipe.
I have then gone into airincupboard and bled the pump although im not sure i have all the air out the system as i can hear a sound that sounds like rushing air/water occasionally.
Now i also notice that on the pump ther eare 3 settings 1 2 and 3, it was set on 2. do i keep it on number 2 ?
Now i spoke to somebody about this and he said what im best doing is summer next year replacing the faulty ballcock in the tank in the loft.alsodraining the entire system ( radiator in lounge has hose pipe connection )
then starting all again.
now all the upstairs radiators dont seem too bad, its mainly the one in the lounge and one in kitchen that dont get as hot as upstairs.
And it also seems that when i turn thermostat up on the boiler to 7 rather than 3 for example, the radiators get colder !!!
Can you advise me on any quick fix, draining , bleeding techniques
