- Joined
- 9 Jan 2022
- Messages
- 6
- Reaction score
- 0
- Country
I would be grateful fir any advice re the following.
We have moved into a house with a Viessman Vitodens100W, believed around 7 years old, serviced by previous owners’ plumber last June. Separate hot water cylinder.
We noticed that on cold days the radiators were only lukewarm even though room thermostats were calling for heat, so rooms never heated (set to 20.5 deg but only reaching 15-17). I checked the boiler display - water temp 57 deg, so I used the dial to increase temp, up to around 69, which required turning dial almost as far as it would go. Seemed to improve heating. Yesterday, very cold outside, again radiators lukewarm, rooms not reaching desired temp. Boiler showed 63. Temp dial had another mm of travel so I turned as far as poss, temp went to 68, seemed to improve radiator temp. Manual says should be able to set heating water temp up to 80 deg, but clearly that is not poss on this boiler. Does this indicate fault with boiler??? Thanks in advance!!
