Hi!!
Can someone please help me, I'm trying to switch over taps on the bath to a bath/shower mixer. I have some plumbing knowledge.
So far (as of now) I have isolated the incoming water under kitchen sink, as there is no in line isolator on cold bath tap, there is one for the hot water tap but doesn't fully stop the flow of water,
I know I need to turn off one of the gate valves in the airing cupboard to stop the flow of hot water, but there are 3, one right at the back which comes from loft then down but can't see where it goes as the cylinder is in the way, (I think this is a 22mm pipe though not sure) another one also comes from the loft on the left hand side but this branches off to the pump & into (I think) 15mm pipes & the last valve is on the horizontal (I'm assuming that this isn't the one I need)
If someone out there can help it would be most appreciated! Thanks xx
