I am about to change the taps on my bath but of the two valves fitted the one to the hot tap will not turn off as it keeps turning with no effect. I understand that it is a gate valve with a red circular handle. Clearly there is a problem with the valve and if this can be fixed I will be glad to learn how.
The alternative is to isolate the hot water supply somehow.
I have a Potterton Profile 100e fanned balanced flue gas fired boiler and if there is a way to turn off the flow of hot water I will be glad to learn this also.
I have read previously that I can turn off the gate valve on the 22mm pipe coming from the hot water cylinder and then run the hot tap until the water stops flowing. I have tried that but the water flow continues.
Solutions to either problem will be appreciated.
