    Dismiss Notice
How to turn off water to hot water bath tap.
Discussion in 'Plumbing and Central Heating' started by PHIL269, 23 Mar 2014.
  1. PHIL269
    PHIL269
    26 Sep 2012
    89
    Thanks Received:
    London
    Country:
    Hi
    Have a problem with my hot water bath tap in that
    when you undo it hardly any hot water comes out.
    Had the same issue with the cold bath tap and it was the spindle which came off but the cold bath tap had its own isolating value so was able to turn off the water to it and fix spindle.
    how do i turn the water off to fix the hot water tap ?
    I have a combi boiler with on demand water in that when you turn on hot water it fires up If I switch off the boiler cold water still flows out hot water bath tap ?
    the cold tap had a isolating value but the hot water bath tap doesn't have one ?
    Any help with this greatly appreciated.
    Many thanks.
  2. Sponsored Links
  3. Burnerman
    Burnerman
    7 Feb 2008
    22,758
    Thanks Received:
    4,441
    Northumberland
    Country:
    Water will continue to flow through your boiler.....until you turn the mains supply off to the house.
    John :)
  4. Charnwood
    Charnwood
    29 Apr 2011
    3,579
    Thanks Received:
    512
    Country:
    Turn off main stop cock.
  5. PHIL269
    PHIL269
    26 Sep 2012
    89
    Thanks Received:
    London
    Country:
    Thanks but cant find where this is, found a
    stop cock under kitchen sink, is this it but it wont turn with my hand ?
    Please help
  6. PHIL269
    PHIL269
    26 Sep 2012
    89
    Thanks Received:
    London
    Country:
    Please help
  7. Burnerman
    Burnerman
    7 Feb 2008
    22,758
    Thanks Received:
    4,441
    Northumberland
    Country:
    Hmm thats a bummer then!
    The chances are it is the mains stopcock.....it may make things easier if you can back off the small hexagon nut where the tap spindle pokes through - thats the gland packing - but the chances are the tap will come free if you can heave on it enough (carefully!)
    There may be an isolator for cold water entering the boiler but I tend to leave those be - leaks there are something you can do without!
    John :)
  8. MrGassafe
    MrGassafe
    26 Oct 2009
    116
    Thanks Received:
    21
    Surrey
    Country:
    Check the cold feed conection at the boiler. Very likely to have an isolating valve there.
  9. DIYnot Local
    3 Sep 2019
    Country:
  10. Sponsored Links
Loading...
Share This Page
