I've just plumbed in my rads with Hep2o and fixed the pipes in the wall exact for the rad.
To keep it looking right I am using the supplied nickel plated 15mm brass pipes that match valves. These are pushed into the elbows coming out the wall. To fit the rad valves.
My concern is I push the pipe in and as always check it's locked in. But I was able to pull the pipe out with some resistance without using the plastic release key. Same on both elbows.
This is a vented gravity fed system but still concerned me. Should I use compression elbows or would you proceed?
