Push fix chrome radiator elbows
19 Jul 2011
Hi folks I have a radiator which I need to take the feeds out below the radiator valves at 90 degrees into the wall behind the radiator.
The radiator valves I have are 15mm compression fittings which I was going to brings down on a 50mm 15mm chrome pipe into a chrome compression elbow into chrome pipe into the wall picking up 15mm hep20 elbow.
However I have seen these
http://www.heatandplumb.com/acatalo...tm_source=ProductSearch&utm_medium=GoogleBase
My questions am I able to put the spigot into a 15mm compression radiator value then push fit 15mm chrome pipe through the wall to pick up the hep20 elbow within the wall or should I stick to chrome compression elbows
Hope this makes sense
Cheers
Jon
Hep2o and I'm pretty sure all the other push fit manufacturers would not reccommend putting chrome plated pipe into a fitting.
The grab ring teeth may not be able to bite into the hard surface plating.
The options would be a compression fitting or carefully file the chrome off the pipe down to the copper, although I'm not sure where you would stand regarding warranty.
But don't risk putting the chrome tube directly into a Pushfit fitting.
Fitting the long chrome part into a radiator valve with a compression fitting should be fine. It is brass construction and that is its purpose. Not sure what you mean about the hep20? The elbow part of the fitting should fit directly onto plastic pipe - not chrome pipe. Also you should use an insert.
