High Pitched whining noise - Vaillant
24 Mar 2008
Glasgow
Hello all,
We've just recently moved into a new flat (completed Dec 06) and our boiler makes a high pitched whining noise when it comes on. It tends to stay noisy for half an hour, stops for a little while, and then the noise begins again. It is an extremely loud whine. The Bar reading is at 1.3 (if thats any use) and it was treated with Fernox Protector in Dec 06....
Any advice on whether I can fix it myself or do I need to get someone out?
Thanks in advance!
Model of boiler would be a helpful start and what it is doing when it is whining.
Hi all,
Thanks for the speedy responses so far, its a 'turbomax plus/pro thermo compact aqua plus' if thats any help. I couldnt find the actual model number this morning but can hunt it out toinght if its needed.
Basically it seems to make a whining noise when it is turning on, or turning back on after it has clicked off. It sounds like the system starts up, and simultaneously the constant whining noise begins. This then continues for 30-45 mins, stops, and starts again 5-10 minutes later...
I can hunt out model number later if you need it...thanks again in advance...
B
