High Pressure or Low Pressure?
23 Jan 2012
Nottinghamshire
Currently got a dripping float valve in my loft cold water tank, doesn't look like too nasty a job to replace and at £6 for a new one it's not going to break the bank, but......
Do I need a low pressure, or high pressure valve?
Looking at them online I can't see a difference outwardly to each one or the one currently fitted? :?
If it's mains fed then get a high pressure valve. They all look the same, but differ internally in the restrictor size.
Ok....fastly running out of my plumbing knowledge.....
Where the water comes from I have no idea. :oops:
It's a 'standard' new(ish) build, the pipe it's connected to disappears off across the loft space and looks like it might go down into the airing cupboard, if I get it wrong will anything bad happen?
It will be a mains fed tank so turn off the main stopcock before attempting the changing of the valve, or if you are that unsure then get a plumber in.
!5 mins work plus a cuppa.
There's a stop cock next to the float valve, that one appears to stop the flow through the valve, I think the biggest problem is going to be finding enough big spanners!
So high pressure part 2 float valve here we come........
What's the worst that can happen.... ;)
