Hitachi nail gun
11 Jun 2021
Hitachi nail gun, fan and shaft have fell of motor, how can I fix this, how was it connected in first place.
I think that the fan is a friction fit on the shaft, but surely the shaft is an integral part of the motor
So how was it connected was it glued to shaft, or was it pressed on?
The fan is on a brass shaft with hole in it? There’s a stainless shaft comes out of motor, stainless shaft fits in brass fan shaft just not sure how stay together as had come apart when took gun apart. I’ve tried glue but no clue if it’ll hold
The brass bush sounds as though it is worn. You will need a new bush or you could try some loctite thread lock.
The bush and fan will be whats known as 'interference' which basically means push fit.
I've just pulled the top off a Senco gas nailer to see how they do it - in that case there appears to be an interference fit boss on the end of the motor shaft with raised tabs (sort of castellated). The fan is pressed onto that and the tabs are peened over to lock it in place.
Looking at the exploded parts diagram for the Hitachi NR90 on the Miles Tool & Machinery site the Hitachi guns are quite different with two sleeves and a nut (presumably Loctited in place) to hold the fan on the shaft
