I have recently had a new Glow-Worm Ultimate 30c installed in November along side a Hive 2 thermostatic controller which i purchased and had installed by my fitters electrician. Ever since the boiler was installed the heating has not been working as it should.
It can sometimes take up to 90 minutes to come on and other times almost instantly(more often not), whether controlled via the app or controller. As far as i can see everything with the Hive2 is linked up as it should be and working, the reciever near the boiler is clicking on when heating signal is sent from controller.
But when i check the lcd display on the boiler after heating has failed to come on i can see the radiator symbol flashing as it should but the flame symbol has not come on to show heating on. Hot water works fine, flame symbol on and tap symbol flashing?
I called the installer out to show this but heating decided to work as it should that day, he seemed to think it was the froststat that was wired in and he removed this.
Didnt make a difference as heating still takes ages to come on. He also thought that maybe the hive was not wired in correctly, but if it is this why would it work as it should somtimes and take ages to come on at other times?
Any help as to what could be causing this would be greatful from anyone who installs Hive or Glowworm or anyone who has any ideas on how to finally get this heating working as it should please.
Many thanks
Many thanks
