hi
I'm interested in fitting a hive controller, but not sure if it's compatible?
My current heating and hot water is done via a programmer - simply a case of on at X o'clock and off at X o'clock - set to Come on twice a day. If the central heating is on the hot water is on. It currently has no temperature setting.
I replaced the programmer a few years ago which was easy enough to do - just screwed onto the original back plate. Would this be the same?
Cheers.
Cheers.
