No heat issues can be due to a faulty element, NTC/thermostat, wiring, pressure switch, or pcb. The element is mounted vertically at the rear of the machine, access to test it is via a cover at the lower centre (rear). There is a sensor on the sump, to get to that you need to lie the machine on its back & remove the baseplate.
