Hole in main water pipe
Philmac 9133. It will fit 3/4" Alkathene.
Stocked by Selco, Buildbase and Plumbase. Branches all over (you don't give your location). Plus numerous independants.
If you need to extend get a Philmac 1332 and a piece of 22mm copper tube; 3/4" Alkathene = 25mm MDPE = 22mm copper. No point forking out more than you need to.
As one of the links was for the philmac universal transition coupling I put 28mm copper as a joiner,
View media item 46903
whats the price difference between 100mm of 22mm and 100mm of 28mm copper?. :|
Excellent info, Charnwood, thanks!
Am in N.Cornwall. Plumbase in Bodmin so will try there.
EDIT**So, if I've got this correct in my head :idea:, if I buy: 2 x Philmac 9133 couplers
1 x Philmac 1332 adapter
and a piece of 22mm copper tube. I should have everything I need to fix it? :D
EDIT** that should probably be only 1x Philmac 9133 coupler shouldn't it? The adapter fits into the end of the coupler? sorry
2 X 1332. One end of each will fit onto your Alkathene, the copper will fit in the other end.
If they've not got the 1332s then 2 X 9133s and 2 X 96003s will do the same job.
for the time being I've just bought the Philmac coupler - if i don't post back, i have probably drowned
Just wanted to bump this thread to say thanks for everyone's help and advice. problem fixed with one coupler and a stop cock key. Cheers guys ! :D Will be back when something else goes wrong! :lol:
