- Joined
- 15 Sep 2019
- Messages
- 12
- Reaction score
- 1
- Country
Hi folks, and thank you in advance if anyone can help here:
Issue:
In User mode:
• When alarm triggered the internal sounder works but the bell box does not trigger - no sound, no strobe.
• Bell test triggers the bell box sound but no strobe.
In Eng mode:
• Eng bell test triggers alarm sound
• Eng strobe test does not accept the given code number (I get the ‘reject’ sound when entered)
Details:
• Securitech 800L /Intellisense AG6 bell box (now replaced with a brand new Honeywell AG6 with identical wiring pattern)
• 800L panel, self installed some 15 yrs ago and battery replaced two years ago & tested as working.
• System has been powered back up after a few years down due to a redecoration & issues with the wiring getting disturbed on a few door sensors but now powered up and works fine after checking & re-connecting all sensors one after the other to eliminate any issues (I ran the alarm without the bell box for a few weeks to make sure no falses etc first).
• Tamper loop on sensors shorted for now to eliminate any possible wiring issues on the tamper loop.
• Internal sounder works fine.
• The 15 yr old original box was ‘tired’ (no led & weathered) so replaced with a new Honeywell branded AG6 box like for like.
• All wires from bell box connected & tamper on bell box tested as working ok (when tamper switch released on box it goes off)
• Bell box was connected as per instructions with panel powered down/battery disconnected and the panel powered back up with all wires in place.
• All wires double checked for ‘SW’/‘ST’ etc before powering up again.
• New bell box has two led’s which are flashing alternate as expected so is powered up ok.
Issue:
In User mode:
In Eng mode:
Details:
