Sometimes the temp is set at 22c, it get's up there then shortly after goes off. When i check the temp button on the programmer, it's down to 5c. Hope you can decifer that.
Changed them about 3 weeks ago, first time in 5 years, then had to get it to recommunicate with the receiver like i say, it goes down to 5c then i have to wind it back up to 21c or to the required setting to get heat back on.thanks.
