Hi all,
Just a quick question I have a Honeywell CM67 Thermostat connected to a Vokera Linea boiler (cant remember the model but I think its 75).
After using the program function on the thermostat and selecting a temperature for any day or time range the slide switch is moved from prog to auto. If required the boiler will fire up to the reach the requested temprature. However if it is required to increase the temp then this only happens for a approx 5 seconds and then the flame light on the thermostat will go off even if the required temperature has not been obtained. If I manually increase the temperature using the temp button whilst in auto mode the flame light remains on and required temperature is obtained.
Any ideas, is my thermostat faulty or does it need some kind of manual reset??
Thanks in advance for your help!
