Hi all
I replaced -rather tried- a vintage honeywell stat with a new cm67. the property has a potterton suprima L for heating (water is supllied through a separate(!!) water cylinder). The boiler is connected to a programmer, an Invesys/Drayton Lifestyle LP111.
The problems started when i tried to wire the cm67. it has 3 connectors, but there were 4 cables coming out of the wall. Red, Blue, Earth & a yellow one. I presumed that the red was live -into connector A- & the blue neutral - into connector B. I taped the yellow, but when trying to operate the system, the programmer fuse blew.
Please any suggestions re wiring would be greatly appreciated!!!
also, is there any use for the drayton or can cm67 operate by itself?
