Honeywell CM921 question?
16 Jul 2015
I'm having problems setting the times on the above wireless room stat.:(
Can it be reset to factory settings or something please?
Yeah, sorry Dan you're correct it wasn't very informative was it.
it's my partners stat feeding a Combi (, I think it's the Worcester, but cant remember the model afraid)
Ive tried to set the room stat to 6am on no1 setting 9am No2
Then set No 3 & 4 stetting for the evening, disabling settings 4 & 5... thus giving heating on twice a day, and not 3 times.
I've tried it the other way around, by disabling 2 & 3 and using 3 & 4 for the evening, but the boiler stays on in between times.
I hope that's clear enough for you?
Well, I did both of what you suggested and unfortunately it didn't work.:(
The boiler still stays on after the off times.
So there's obviously something amiss.
Perhaps I should call Honeywell to see if they can help?
Just to clarify..
1) will be CH ON in the morning and should be set to 21C if that's how warm you'd like it.
2) 3) 4) should all be set low (eg 12C) so there's no danger of the heating coming on at those settings and it will stay OFF from the time set by number 2.
5) will be CH ON in the evening, again set this to 21C or as warm as you wish.
6) should be set low (12C ?) so the heating stays OFF overnight.
good news :)
It seems to work OK now.
I set it to go off at 9pm set to 10 degrees.
and it was off when we got in at 11ish.
Many thanks for the help:cool:
