i recently bought the honeywell cm927 controller on the recommendation of a couple of friends. Since i installed it it has never run to the programmed times? All it seems to do is work as a room thermostat and switches the heating on and off according to temp setting.
As far as i can see from the wiring diagram the receiver is wired correctly (heating is coming on and off) - so i presume the issue is with the transmitter (control box)
the wires from the fuse spur go to the block inside the boiler then there is the block for switching wires (this is the one that has the connector in when not using external controller)
wires in the receiver are as follows
live comes from +ve on fuse spur block and goes to l next to n
negative comes from fuse spur block and goes to n
i've jumpered the two L's together
A and B are the 2 wires that go into the control block
if any one has any suggestions to why it only works as a thermostat and not timer they would be greatly received - (yes the controller has been switched to auto!)
i believe the fault lies with the controller and not the wiring (The receiver is receiving a signal and turning the heating on and off as it should do - its just getting the signal when the heating should be off)
