Honeywell DT92E
14 Oct 2010
Sussex
Ive just bought a Honeywell DT92E wireless thermostat thinking it would be as easy to wire as a plug is... I unclipped my existing Danfoss to find 3 wires (red, yellow and blue and an earth (the latter is not connected)). The Honeywell instructions ask for lots more and I'm completely lost. Before I do the right thing and call an electrician is there anyone who knows the product and can help me out.
Which wire is on which terminal on the old stat
What model danfoss stat is it
Probably one of the three wires is a neutral - we need to sort out which is what.
EDIT:
Probably it will be:
Red to L
Blue to N
Yellow to B
link between L and A
BUT
need to check the existing first as it may have been wired in a not normal way (and that happens A LOT!)
Thanks for the reply.
Im using a Danfoss RMT 230 at the moment
From left to right there are four connections numbered 4-1-3-2 in that order.
Blue is into 4, yellow (with a red tape round it) is into 1, 3 is empty and 4 is red.
hope that helps!
Thank you... you got it absolutely right and it all works now, looks good and is economical
Thanks again
