Honeywell Galaxy MK7 Keypad
13 Jun 2013
Bedfordshire
Hi all;
I wondered if anyone can help me, whilst repositioning a PIR at my home the electricians short circuted the power supply to this and blew the 0.5A Aux fuse on the alarm panel, I have since replaced this and all PIR's are now working but since then the keypad screen has been flashing and all it shows is a load of hashes, (########).
how can I remedy this? do I need to re-set the whole panel, if so how?
Your help will be much appreciated.
Sam
Hashes and not stars ?
The keypad should have come back on-line when power was connected. Open the panel, power off mains and disconnect the battery. Reconnect mains, then the battery to see if the keypad will come back. It takes about 10 seconds to boot. If it's still not showing the display after that point, then the bus may be damaged.
Many thanks for your response, did as you instructed and is all sorted now.
I wondered if you could help me with this other on going problem I am having, once the alarm has gone off, entering the user code stops the internal sounder but the outside bell carries on until it re-sets itself after 15 mins.
is there a problem with the wiring or this a setting which is wrong.
many thanks,
Sam
Sounds like a wiring issue. Either that, or you have reprogrammed the output from Bell to something else. Post a pic or detail how you have the sounder wired.
Hi, please find attached picture of the wiring diagram.
regards,
Sam
How about at the siren side ? Also, have you changed the output programming ?
