    Dismiss Notice
The Galaxy Mk7 Keypad fault xxxxxxxxxxxxxxxxxxxxxx
Discussion in 'Alarms, CCTV & Telephones' started by BigDick, 29 Jan 2013.
  1. BigDick
    BigDick
    29 Jan 2013
    6
    Thanks Received:
    Birmingham
    Country:
    hi just put a Galaxy Mk7 Keypad on to an old alarm in a shop but all that is on the lcd is xxxxxxxxxxxxxx can any one help please :cry:
  2. Sponsored Links
  3. oasistechnical
    oasistechnical
    26 Dec 2009
    681
    Thanks Received:
    118
    Hampshire
    Country:
    it usually means lost comms from end station,
    soft reset should cure it, and new battery in end station.
    Oasis
  4. EightyTwo
    EightyTwo
    14 Feb 2012
    1,117
    Thanks Received:
    169
    Cambridgeshire
    Country:
    Check the address...
  5. oasistechnical
    oasistechnical
    26 Dec 2009
    681
    Thanks Received:
    118
    Hampshire
    Country:
    if the system has been powered down for a long time it can, and i state can, lose settings.
    unless the system keypad has been removed or the rotary address switch played with losing address is really not an option.
    even if he fits a new keypad, it comes auto addressed as 0.
    change the battery, soft start the panel and then see what happens, but be aware all galaxy panels are engineeer tamper reset only, so if you remove the end station cover you will generate a tamper alert.
    the other bit of advice is to find a local firm that will come out and do it for you,
    what model is the panel, not the keypad, as that will be a CO37 or CO38
    the main box, (end station) this info would be helpful.
    Oasis
    and yes we do Galaxy !!!
  6. EightyTwo
    EightyTwo
    14 Feb 2012
    1,117
    Thanks Received:
    169
    Cambridgeshire
    Country:
    Sorry, Oasis. I didn't mean to offend or suggest that you were wrong :oops:
    I didn't know where the keypad had come from - it might have been a "previously enjoyed" one too...
  7. oasistechnical
    oasistechnical
    26 Dec 2009
    681
    Thanks Received:
    118
    Hampshire
    Country:
    thats ok mate, no insult intended, and yep i undersant that the keypad could have been `previously enjoyed item` !!
    Oasis
  8. BigDick
    BigDick
    29 Jan 2013
    6
    Thanks Received:
    Birmingham
    Country:
    hi thanks for the advice have got the keypad to run but now when i put in the user code it says mod is missing i have removed one keypad as there was 2 on the alarm any advice
  9. sparkymarka
    sparkymarka
    16 Feb 2011
    7,366
    Thanks Received:
    1,123
    Sheffield
    Country:
    do you have the engineer code ? as you will have to enter engineer mode then exit and it should say modules before xx modules now xx ( one less than before) press enter.
  10. Sponsored Links
  11. BigDick
    BigDick
    29 Jan 2013
    6
    Thanks Received:
    Birmingham
    Country:
    no i dont is there any way to reset
  12. BigDick
    BigDick
    29 Jan 2013
    6
    Thanks Received:
    Birmingham
    Country:
    is there any way to default set the mk7 ad the g2-20 board thanks
  13. oasistechnical
    oasistechnical
    26 Dec 2009
    681
    Thanks Received:
    118
    Hampshire
    Country:
    if your panel tells you MOD MISSING it should also prompt you to press the star or hash key to accept removal of the device.
    ensure that the only keypad on the system is set at `0`
    or it might not find it
    any other probs please repost
    Oasis
  14. BigDick
    BigDick
    29 Jan 2013
    6
    Thanks Received:
    Birmingham
    Country:
    hi thanks for the reply but it does not prompt me to press the star or hash key any advice would be welcome thanks
  15. EightyTwo
    EightyTwo
    14 Feb 2012
    1,117
    Thanks Received:
    169
    Cambridgeshire
    Country:
    Yes, there is a way to default the Galaxy, but I'm afraid that I'm not going to put it on a public forum, sorry! :(
  16. BigDick
    BigDick
    29 Jan 2013
    6
    Thanks Received:
    Birmingham
    Country:
    is there any way you could email it to me thanks
  17. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
