Hi
I have a Honeywell CM927 wireless thermostat that comes with the HC60NG relay unit. My relay unit has passed away and needs replacement. I noticed that Honeywell uses the same HC60NG relay unit in all its wireless thermostat products. Can I use the HC60NG unit from the Analoque Wireless Room Thermostat Y6630D1007?
Note that the diagrams depict different power wiring in each case. The unit has a single neutral and 2 live connection pins. ( I have a combi boiler)
for cm927
http://europe.hbc.honeywell.com/netherlands/productcatalogue/pdf/en0h8556uk07r1006.pdf
for Y6630D1007
http://europe.hbc.honeywell.com/products/pdf/en1b0344-ge51r1105a.pdf
I would appreciate anyones assistance on the issue
NOTE
the HC60NG comes in various editions but as I understand the only difference is the supported language....How can be power wiring different...
for cm927
for Y6630D1007
NOTE
