Honeywell Home T3R Question
14 Apr 2022
Hi All,
I have an Honeywell T3R Thermostat being used with a Worcester Bosch 4000 30kw boiler and it keeps turning on the boiler every 5 minutes even tho the temperature in the room is the same as the temperature set for that programme period, is this normal?
No it’s not normal. How recent is the boiler and thermostat? Has it done it since it was installed?
Hi All,
Not every 5 mins but normal if its every 10 mins whilst the thermostat is going thru its learning phase. The thermostat is TPI and is maintaining the room temperature by constantly calculating how much heat is needed from the radiators to maintain the room temperature. The default setting is to cycle the boiler 6 times an hour, i.e. every 10mins. This can be adjusted but the recommendation for a gas boiler is 6 cycles. By default the minimum boiler on time is 1min.
Yes it's done it since it was installed.
The link between L and CH has been removed, but the link between L and DHW is in place.
That could be it, how long does it need to finish learning? Yes the cycle is set at the default of 6 and the min. on is at the default of 1 min.
