Hi
The ST799 controller on my heating/hotwater has become very intermittent. It will run for around ten minutes (either HW or CH) and then the display goes blank and the boiler turns off.
If I press the reset button it will run again for a few minutes then turn off again.
I've Googled around and the usual advice is to replace the battery but took the front panel off, checked the backplate connections are ok, checked the battery voltage which is at 3.2V and have noted even with the display off overnight when reset next morning the time is correct so it looks like the battery is doing its job?
Has anyone come across similar symptoms? as usual its picked a great time of the year to fail
thanks
Bob
thanks
Bob
