Honeywell sundial y plan issue...
20 Nov 2003
I noticed the other day that the radiators were getting slightly warm in the mornings when the hot water was coming on.
I removed the actuator (note only one screw was holding it in place...)
The valve stem moves. 10-15 deg to the left, 5-10 to the right, when 0 is at right angles to the pipes. When running I did move it to the left and it all started clunking... So I stopped doing that(!)
So is this range of movement expected?
Is it meant to clunk when moved to the left?
Cheers,
M
So I might get away with a new plate with ball then... Hmmm
If I leave the stem (without actuator) at the central position what ports are open?
