But, did you do as Matt said, and check whether the overheat stat on the cylinder has tripped. If it has it would give the exact symptoms you have.
One further point is taping a wire that is live (it will be live when the motor is not energised) is not considered making safe, it should be wired into a spare terminal/choc block.
